2 members (joe apple, jmoore), 129 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#116729 07/04/2005 2:44 AM
Just curious, the running board on my 52 need a little touch up, chips,etc,, they are red and match the truck, I was curious about maybe covering the with some of that bed-liner stuff , how do you think they would look with it and black, guess it would keep one from slipping on them when wet,,, just a thought,,,,Fred
Just drive em................................
Redryder pix
My Hotrod
#116730 07/04/2005 3:01 AM
I think they woulda been black originally Fred, and you may have hit on a good use for that stuff - I don't like it in truck beds, but I'd think it might be good on the boards - keep'em from being slippery as you say, and I don't think it would get scratched up as easy as paint - be a guinea-pig for us, and report on how it works! grin
#116731 07/04/2005 3:32 AM
Joker I used the bed liner sold a Wall MART IN THE SPRAY CAN ON MY RUNNING BOARDS. tHE SPRAY can stuff gives a less rough texture. I like the way it looks and it seems to last good. Ronnie
#116732 07/04/2005 7:35 AM
I used some stuff called durabak on my bed turned out great. and you can get several diffrent colours. what great is you can get it with or without the ground uprubber.
http://www.nonslipcoating.com/
DustyG.
1952 Chevy 1.5 ton
1949 Gmc 2 ton flatbed Dump
#116733 07/04/2005 2:53 PM
We put Herculiner in our bed and on the running boards of our '54 (about $100 per gallon - one gallon did bed AND running boards with about 30% left over). The final result looks pretty good.
The running boards and bed were used hard over the past 50 years, and we intend to drive our truck, so the bed liner solution was a good choice for us. Turned out well enough that the '63 is also going to get the same treatment.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#116734 07/06/2005 12:28 AM
you got any left over,,,well, it never hurts to ask,,,,,,,,,,,,,Fred
just drive em...
Redryder pix
My Hotrod
#116735 07/06/2005 1:42 PM
I do! But I don't think UPS will let me ship it to you in an ice cream bucket . . . smile
~ Kimberly
#116736 07/06/2005 2:50 PM
Sunlight seems to affect Herculiner, on my 79 I did the inside of the bed-sides look great still, but the bottom & wheelwells that are exposed are faded & peeling off pretty bad. Surface prep was the same(blasted) so I am guessing it is the sunlight. Truck lives outside. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
