| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Hi everyone, I have a 54 235 and plan to start it up for the first time, I see lots of discussion about engine oil for these vintage engines. What are BC Bolters using for engine oil in their trucks. any thoughts would be appreciated...Glenn
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Oct 2014 Posts: 56 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 56 | Look at using an oil with ZDDP in it. It's a zinc-based anti-wear additive that helps lubricate our vintage beasts.
There are vintage specific oils you can purchase but they can be ridiculously expensive. I have heard diesel oils have the required ZDDP but you want to be sure not to get one with too high of a detergent level in it as that can be bad for the engine.
Alternatively you can buy a zddp additive. Maybe check at Lordco or your fav. parts supplier... or of course you can buy it on Ebay or Amazon. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | Can you get Valvoline VR1 up there in BC? I buy it here in Texas, though I have a tough time getting several quarts of the same weight at the same store, so I have ordered it from Amazon in a case of six to avoid having to visit multiple stores. | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Hi EBS, I will check that out, thanks for the info
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I think that was I used on the last change. Had to order my filter on line. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | |
