3 members (rfs56trk, Wally / Montana, Gdads51), 93 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#1165990 05/19/2016 2:47 AM
I have a 49 pickup 3100 with a 235 that came out of a 62 impala. I would loike to change over to a three speed on the floor. I now have the three speed on the column. What kind of problems should I expect with this type of change over. also what does the floor shifter attach to. I do appreciate any help along this line. thanks
A 1947 AD came with a 3 seed on the floor. After then, the shifter arms were located on the side of the transmission making conversion to on-the-floor shifter a big challenge.
Gas Pumper
Gas Pumper
Yeah, a HUGE challenge. You really have two choices. You can install the shifter real close to the seat and to the left, then compensate for that installation with a modified stick, or go here:
http://www.devestechnet.com/Home/ShifterMech
This works flawlessly and I am very pleased with how it works, but it's not at all easy.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Guys, I have a 1950 1/2 ton PU (stock 216) working through an uneven front brake situation. Would love to convert to a floor shift conversion like the ones that filled the adds in Hot Rod Magazine in the sixties. I can see how the setup would be offset toward the left side, but could get along with this.
Where to look- any websites like devestechnet covering this?
If you swap to a 4-speed (Muncie or Saginaw), T & F Shifter makes a shifter that puts it in the original location, front and center.
http://www.hotrodscustomstuff.com/OLD_SITE/TFshifter.html
I have one of these in my '56 3100 and really like it!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The shifter kits I'm trying to find mount to the left side of thr transmission and has two short pushrods to the trans. arms or bellcranks. Used to cost about $25-35, so today inflated somewhat.
Anybody have one for a '50 Chev. 1/2 ton pickup? (With pix and instructions) Thanks Guys
Hi, dynsor, google popular mechanics magazine for plans to make a stick shift for a column shift car. When I was in high school in the late '60s, the medal work teacher had plans to make a stick shift kit.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Dynasoar....Email sent
1959 3100 Apache Fleetside
