| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** For Those Interested ** I just received 2 reproduction reels from the Pullman Co. {The Orig. Supplier To GM} price $28.50 each. They are nearly a dead ringer to the orig. ones. The only mod. I had to make was lower the hole for the tape that connects to the cable a little. They are rated 11 to 13 pounds pull where the orig. ones were 9 to 11 lbs. ** Good Luck To All. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Marzach;
Do you have the original cables? If not, what did you do for cables? They really seem to be the long pole in the tent.
Larry
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Larry ** The orig. cables are still in the Suburban and in great shape. | | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | I am very pleased to note that my discovery of the Pullman Co. retractors is bearing fruit in this community. I got mine about a month ago, mounted them without any modifications, and they work very well. www.pullmanbalances.com Best Regards,
Lisa
1952 Chevy Carryall in completely original condition Pulled out of a barn in Colorado high desert
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | I ordered mine today They were Pullman 105A That's what I removed from 49' burb | | |
