| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | I am getting ready to paint my truck and I have always used acrylic enamel without hardener.
Now, I would like to use hardener. What is the ratio? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It probably would be safest to check with the manufacturer of the paint you are using (or check the paint's product data sheet). | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | PPG (Delstar) No Hardener... 1 gal. color : 2 quarts reducer
PPG (Delstar) With Hardener... 1 gal. color : 3 quarts reducer : 1 pint hardener
You should be able to do the math from there. But thats just for PPG and OMNI, I don't know about the others.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | Thanks for the info.
I don't do a lot of painting.
the reason I have never used hardener is because I wanted to practice wet sanding and buffing to see how much I am taking off. Then, I will start all over and re-paint.
I guess now, from what I am reading. It is base coat/clear coat is the way to go.
Thanks alot! Appreciate it! | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I don't measure the hardener. I just pour about 2oz in with each full canister of paint. Better to use to much than to little. I just painted my Honda car and it looks great.
delete my account and pictures
