1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#116656 06/27/2005 4:34 PM
Junior Member
Junior Member
I am getting ready to paint my truck and I have always used acrylic enamel without hardener.
Now, I would like to use hardener. What is the ratio?
#116657 06/27/2005 6:10 PM
It probably would be safest to check with the manufacturer of the paint you are using (or check the paint's product data sheet).
#116658 06/28/2005 12:33 AM
no hardner?
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#116659 06/28/2005 2:59 AM
PPG (Delstar) No Hardener...
1 gal. color : 2 quarts reducer
PPG (Delstar) With Hardener...
1 gal. color : 3 quarts reducer : 1 pint hardener
You should be able to do the math from there. But thats just for PPG and OMNI, I don't know about the others.
Keith
If it were easy they'd have grade schoolers doing it!
#116660 06/28/2005 5:49 PM
Junior Member
Junior Member
Thanks for the info.
I don't do a lot of painting.
the reason I have never used hardener is because I wanted to practice wet sanding and buffing to see how much I am taking off. Then, I will start all over and re-paint.
I guess now, from what I am reading. It is base coat/clear coat is the way to go.
Thanks alot! Appreciate it!
#116661 07/01/2005 5:52 AM
Tab Offline
I don't measure the hardener. I just pour about 2oz in with each full canister of paint. Better to use to much than to little. I just painted my Honda car and it looks great.
delete my account and pictures
