0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Check out my Posting in the Driveline Section ://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1070587/Searchpage/1/Main/157950/Words/mribbich%40wi.rr.com/Search/true/Re:_Tired_Of_Double_Clutching?.html#Post1070587 | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | | | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 |
1954 GMC 350-27
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Solicitation for a product?
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What does this thing do? Details and description would help a lot. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Harold It lets you use Art Deco clutch/ brake peddles on a SM420 bellhouseing , witch doe's not have mount for the shaft. I did this 15 years ago, and can be fabed up very easy. Piece-O-Cake.
| | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | Harold It lets you use Art Deco clutch/ brake peddles on a SM420 bellhouseing , witch doe's not have mount for the shaft. I did this 15 years ago, and can be fabed up very easy. Piece-O-Cake. Turner? Where? Funny seeing someone so close on here! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | This thread is more or less double posting which is generally not accepted in the forum. The title/subject is also sort of vague as illustrated by the initial replies with questions about just what this is about. The title could be clearer if it mentioned years/models affected and something about pedal bracket or later model transmission swap.
We can find some more pointers and suggestions for good effective posting here https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/380532/Why_posts_are_edited,_moved_or.html#Post380532
This thread is now locked. In the future let's try to avoid double posting and strive for clear descriptive thread titles.
Thanks, Grigg | | |
