2 members (Otto Skorzeny, 1955 1 Series), 105 guests, and 4 robots.
Topics128,187
Posts1,057,212
Members48,465
Check out my Posting in the Driveline Section
://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1070587/Searchpage/1/Main/157950/Words/mribbich%40wi.rr.com/Search/true/Re:_Tired_Of_Double_Clutching?.html#Post1070587
btt
Is this a question?
1954 GMC 350-27
Solicitation for a product?
What does this thing do? Details and description would help a lot.
Harold
Harold
Harold
It lets you use Art Deco clutch/ brake peddles on a
SM420 bellhouseing , witch doe's not have mount for the shaft. I did this 15 years ago, and can be fabed up very easy. Piece-O-Cake.
Originally Posted by T-RUCK
Harold
Turner? Where? Funny seeing someone so close on here!
Check out the posting in Driveline section to see what is all about. Copy and past this link, read each posting and one will show pictures. https://www.stovebolt.com/ubbthread...f_Double_Clutching?????.html#Post1070562
Marv.
This thread is more or less double posting which is generally not accepted in the forum.
The title/subject is also sort of vague as illustrated by the initial replies with questions about just what this is about. The title could be clearer if it mentioned years/models affected and something about pedal bracket or later model transmission swap.
We can find some more pointers and suggestions for good effective posting here
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/380532/Why_posts_are_edited,_moved_or.html#Post380532
This thread is now locked.
In the future let's try to avoid double posting and strive for clear descriptive thread titles.
Grigg
