4 members (Forty9, Hotrod Lincoln, thekid1950, Wayne67vert), 42 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#1166392 05/22/2016 1:33 AM
Here may be a new one
I did a search of stalling before writing this
After getting my 235' 1949 Suburban running and driving for about 2-weeks, it's starting to stall while driving.
It will bog out, then die; before that it was driving with no issues.after stalling, I can pretty much re-start and take off driving. It may or may not stall on the way home. Compression is good with all cylinders around 120-125. The plugs are white with the exception of #2 cylinder which is a little black. Power is a little low compared to my 250 cid 66' suburban. Climbing a small hill has to be done in 2nd
Details
235ci
Cleaned and coated gas tank
New lines
New fuel pump
Rebuilt carb
New ignition components and plugs
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
Suburban Lou #1166393 05/22/2016 1:42 AM
When it stalls, does it act like it would if you ran out of gas, or more like someone turned the key off on you?
Suburban Lou #1166397 05/22/2016 1:50 AM
Gas tank with floating crud. As you drive it works its way to the outlet for the gas tank and temp blocks the opening. When the engine stops the suction stops and gas flows again.
Suburban Lou #1166415 05/22/2016 3:34 AM
@52carl
Kinda like it ran out of gas
It shouldn't I just had the tank cleaned
The glass bowl filter on the pump is full. Is it a suction problem
"Bad Guy"
"Big Guy"
Suburban Lou #1166429 05/22/2016 4:09 AM
A sticking needle or float, maybe...?
Suburban Lou #1166431 05/22/2016 4:31 AM
Maybe
Carb is rebuilt so I hope not
"Bad Guy"
"Big Guy"
Suburban Lou #1166545 05/23/2016 12:57 AM
When I have a sporadic issue like yours, I just drive the truck until it either gets better, or gets worse. When it gets worse, it is easier to diagnose the cause. If it gets better, that means the gremlin found its way out by itself.
Suburban Lou #1166577 05/23/2016 5:17 AM
Hey Carl
I may have found the issue
When trying to get the truck started, I swapped a newly rebuilt carter carb in for the original Rochester that was installed. During some trouble shooting and because of the lack of power I had my son floor the gas pedal (engine off) to verify the linkage travel and stroke of the carb linkage. Full travel on both and the carb hits the stop
But, when looking down the carb, it only opens a quarter inch, at best. After checking the original Rochester carb, full stroke when actuated by hand pretty much rotates the throttle plate 90 deg.
So I am thinking interference with the insulator? Since the original carb wasn't the problem with starting, I will put it back in tomorrow
Your thoughts?
Thanks Lou
"Bad Guy"
"Big Guy"
