3 members (Lostbuthaulinass, MNSmith, festerhairball), 99 guests, and 2 robots.
Topics128,057
Posts1,055,814
#1165624 05/16/2016 7:13 PM
I recently bought a 48 Chevrolet Maple Leaf with a gvw of 15500lbs, Im looking for part numbers for wheel seals, pinion seals and transmission output shaft seal, does anyone have this info?
Jaredm #1165666 05/17/2016 12:32 AM
Any pictures you can post ? We don't get to see Maple Leafs that often.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Jaredm #1165668 05/17/2016 12:38 AM
Big Bolt Forum Moderator
welcome to t he site! Mine are newer, someone should be along shortly that is more familiar with the AD trucks and have some part #s for you.
Mike
Jaredm #1165712 05/17/2016 3:44 AM
I dont think it will let me post pictures yet. its got 38000 miles on it and no rust except surface rust on bottom of cab and fenders, just working on getting it a little more road worth.
Jaredm #1165758 05/17/2016 3:13 PM
3B Offline
Hy Jaredm, welcome, could you post your serial number and tell us if your truck has a single or two speed rear axle please?
Jaredm #1165783 05/17/2016 5:41 PM
Red dot, center of chest ...
You can't post pictures on the forum. You need to use a Photobucket account, or Google or something similar (Dropbox, etc.)
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
3B #1165786 05/17/2016 6:16 PM
I will get the serial number this afternoon. Yes it is a 2 speed, I ordered a seal for a eaton 16600 rear, hopefully its right.
Jaredm #1165818 05/17/2016 11:44 PM
so the seal I ordered for a eaton 16600 was about 0.5" to big, back to square one. The serial# 8167300762 and it has a 2 speed. any help would be appreciated
Jaredm #1165851 05/18/2016 3:26 AM
3B Offline
Hy Jaredm, the front hub seal was originally a felt, some seal manufacturers list a rubber type replacement some don't, I can't find a parts book that lists a rubber replacement for a 16 series 1948 Chevrolet Maple Leaf (2 1/2 ton truck) but if you disassemble and give us the I.D., O.D., and thickness we should be able to find a seal for you. The rest of these are O.E.M. numbers crossed to Napa numbers
Pinion seal O.E.M. 2082925 = Napa NOS 20098
Inner rear hub seal O.E.M. 5830526 = Napa NOS 33306
Transmission output seal O.E.M. 591448 = Napa NOS 22336
Hope that helps.
3B #1165884 05/18/2016 1:26 PM
Thanks for the help, I will try that napa inner rear seal number. The OD is 5" and ID is 3.250. Any idea of what rear axle it might have? I am assuming its not a eaton 16600 as the seal for that axle was wrong.
Jaredm #1165984 05/19/2016 1:55 AM
I think I found a inner hub seal thanks to 3b, its on its way. While trying to bleed the brakes this afternoon, one of the front flex hoses blew, does anyone know if the hoses on my 2.5 ton will be the same as the 1/2 ton trucks?
Jaredm #1166001 05/19/2016 3:24 AM
Check out rock auto they list a few and it looks like they are the same for different models.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Jaredm #1166107 05/19/2016 11:50 PM
3B Offline
Hy Jaredm, the O.E.M. front brake hose part number is 2002111 which crosses to Napa part number UP 24458, hope that helps.
3B #1166501 05/22/2016 7:35 PM
Glad others were able to help. If you want to PM me I have the Canadian shop manual for 48 to 51 Chevy and GM trucks. It is ambiguous for parts info stuff, thats a different book I think.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
