13 members (Bill Hanlon, Oldcaliforniakid, Southerntruck, D B Cooper, Peggy M, Jims46, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 2-Ton, 2 invisible),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | I recently bought a 48 Chevrolet Maple Leaf with a gvw of 15500lbs, Im looking for part numbers for wheel seals, pinion seals and transmission output shaft seal, does anyone have this info?
Thanks | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Any pictures you can post ? We don't get to see Maple Leafs that often. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to t he site! Mine are newer, someone should be along shortly that is more familiar with the AD trucks and have some part #s for you. | | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | I dont think it will let me post pictures yet. its got 38000 miles on it and no rust except surface rust on bottom of cab and fenders, just working on getting it a little more road worth. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jaredm, welcome, could you post your serial number and tell us if your truck has a single or two speed rear axle please? | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | I dont think it will let me post pictures yet. its got 38000 miles on it and no rust except surface rust on bottom of cab and fenders, just working on getting it a little more road worth. You can't post pictures on the forum. You need to use a Photobucket account, or Google or something similar (Dropbox, etc.) | | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | I will get the serial number this afternoon. Yes it is a 2 speed, I ordered a seal for a eaton 16600 rear, hopefully its right. | | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | so the seal I ordered for a eaton 16600 was about 0.5" to big, back to square one. The serial# 8167300762 and it has a 2 speed. any help would be appreciated | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jaredm, the front hub seal was originally a felt, some seal manufacturers list a rubber type replacement some don't, I can't find a parts book that lists a rubber replacement for a 16 series 1948 Chevrolet Maple Leaf (2 1/2 ton truck) but if you disassemble and give us the I.D., O.D., and thickness we should be able to find a seal for you. The rest of these are O.E.M. numbers crossed to Napa numbers Pinion seal O.E.M. 2082925 = Napa NOS 20098 Inner rear hub seal O.E.M. 5830526 = Napa NOS 33306 Transmission output seal O.E.M. 591448 = Napa NOS 22336 Hope that helps. | | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | Thanks for the help, I will try that napa inner rear seal number. The OD is 5" and ID is 3.250. Any idea of what rear axle it might have? I am assuming its not a eaton 16600 as the seal for that axle was wrong. | | | | | Joined: Aug 2010 Posts: 24 New Guy | | New Guy Joined: Aug 2010 Posts: 24 | I think I found a inner hub seal thanks to 3b, its on its way. While trying to bleed the brakes this afternoon, one of the front flex hoses blew, does anyone know if the hoses on my 2.5 ton will be the same as the 1/2 ton trucks? | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Check out rock auto they list a few and it looks like they are the same for different models. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jaredm, the O.E.M. front brake hose part number is 2002111 which crosses to Napa part number UP 24458, hope that helps. | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Glad others were able to help. If you want to PM me I have the Canadian shop manual for 48 to 51 Chevy and GM trucks. It is ambiguous for parts info stuff, thats a different book I think. | | |
