5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
Putting a power disc brake setup under the floor on a 55. Debating on going with carpet, but maybe a floor mat would be better?
Any pictures of carpet with the whole cut in it? Trying to see how clean we can make it using carpet.
Opinions? Thanks
I don't have disc brakes but if I did I still like the M/C where I put it. Out of the way! ...its a 52 panel but here is what I did. Not too fancy but it serves the purpose.. I used a rubber floor mat and just turn it back if I want to check the M/C. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/MasterCylhole001.jpg
On my '56 restorod I used a remote dual reservoir mounted on the fire wall and this billet MC cover. Works great...without this you can use a mirror and squeeze bottle with a long straw to fill the MC from underneath if you want.
http://www.kugelkomponents.com/zencart/index.php?main_page=index&cPath=49
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the ideas. I was looking at this finished edge molded carpet and thought I might be able to put some velcrow on the edge and pull it up to get to the master cylinder.
Big Bolt Forum Moderator
I used a remote reservoir kit as well in my 59 Suburban, not sure what I will end up with on the 58 2-ton, probably glue the carpet to some thick pad and as mentioned above, just pull it back when I need to check the master Cyl. Gluing the carpet to some thick jute pad (heavier fiber/hair type, not rubber) will make it lay a lot more like a rubber floor mat and not bunch up or wrinkle.
Mike
