1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
Has any one got any info on puting a 1959 chevy dash in a 1959 gmc.
what kinda info? only way is to remove the windshield, drill out about 50 spot welds the are part of the joint that makes up the lower flange that mounts the windshield rubber, cut away the braces underneath, including the one that holds/positions the steering column, and reverse the process to install the other one, which has been removed the same way grin
been done, but waaay easier to find a useable Chevy cab and sell the GMC cab
Why would you want to?
Well i think the gmc dash is just kind of work truck looking, like it would go good with a fleet edition truck but i drive this thing every day and i want to look at something that is, well more appealing to the eyes. It doesn't have to be a chevy dash i just want to emprove the look of the current dash.
Actually the GMC fleet option trucks used the Chevy style instruments.
I take it your dash has the painted panels with the white guage surrounds. You could replace them with the turned metal ones with chrome surrounds from a deluxe cab.
Well they should have used the gmc dash in the fleet truck to match those ugle headlight assemblees
Junior Member
Junior Member
I wouldn't start cutting into your dash just yet until you know which dash is going back in. The possiblities are endless. I have seen a '59/'60 impala dash on a '50 pickup and it looked custom, but part of the old dash was blended into the new dash. There was a lot of metal work done to make it look good.
Why not sell the truck and buy another truck with the dash you want?
Dennis
We will be manufacturing "Custom Dashes for the 55-59 GMC dash in the near future! Richard
www.ricos-rods-and-relics.com
If you think you can you are right! If you think you can't, you are still right!
www.ricos-rods-and-relics.com <stop in and see me!>
Put a Dakota Digital insert in it.
