11 members (Gdads51, Gray_Ghost, Woodcmiami, Shaffer's1950, Nick in Manitou, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, 2 invisible),
84
Mod | | | Forums66 Topics128,131 Posts1,056,372 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | Has any one got any info on puting a 1959 chevy dash in a 1959 gmc. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what kinda info? only way is to remove the windshield, drill out about 50 spot welds the are part of the joint that makes up the lower flange that mounts the windshield rubber, cut away the braces underneath, including the one that holds/positions the steering column, and reverse the process to install the other one, which has been removed the same way been done, but waaay easier to find a useable Chevy cab and sell the GMC cab Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | Well i think the gmc dash is just kind of work truck looking, like it would go good with a fleet edition truck but i drive this thing every day and i want to look at something that is, well more appealing to the eyes. It doesn't have to be a chevy dash i just want to emprove the look of the current dash. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Actually the GMC fleet option trucks used the Chevy style instruments. I take it your dash has the painted panels with the white guage surrounds. You could replace them with the turned metal ones with chrome surrounds from a deluxe cab. | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | Well they should have used the gmc dash in the fleet truck to match those ugle headlight assemblees | | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | I wouldn't start cutting into your dash just yet until you know which dash is going back in. The possiblities are endless. I have seen a '59/'60 impala dash on a '50 pickup and it looked custom, but part of the old dash was blended into the new dash. There was a lot of metal work done to make it look good. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Why not sell the truck and buy another truck with the dash you want?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2004 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 13 | We will be manufacturing "Custom Dashes for the 55-59 GMC dash in the near future! Richard www.ricos-rods-and-relics.com | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Put a Dakota Digital insert in it. | | |
