0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
I want to install the oil filter on my '54 3100 series PU. can someone here send me a layout showing the correct ports on the block to connect to. Does the oil pressure line tee off the line to the filter? I have a Fenton header so the original filter will be mounted to the firewall.The truck was disassembled when I got it.
also , where can I reference the engine # ,0478860F54X3
so I know what I have.
John Baker
[email protected]
John,
Here are the oil filter port locations on the block of a 1954 235 engine.
I use a brass T joint at the input port on the oil filter (upper right port on the 54/55 canister).
F54X code (I do not know what your "3" designates).
Thanks, I appreciate the info.
Tim, I bet the 3 is a "B" making it a "XB" 3800 Series engine.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, Mike,
I am packing for a move from NC to NY and did not spend enough time looking at the 1954 Chev Truck Ser Nos. Spec sheet.
