| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | Can someone tell me (or refer me to a drawing) of cross sill spacings for my '53 3100 short bed? | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I will look for some measurements for you tonight. Do you have the truck frame accessible? There should be holes in the frame for the cross sills. A '55-'59 3100 is not what you are asking about... However, I have a 1955.2 and here's the factory assembly manual (FAM) page of a '55-'59 showing the cross sills. Again, I understand you are asking about a 1953, but maybe this will help (?). Brad Wrench Fetcher, PhD | | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | The frame is accessable, I am installing a new bed, as the PO had an International bed installed, and most all of the holes were welded up. | | |
