| | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 60 | Putting a power disc brake setup under the floor on a 55. Debating on going with carpet, but maybe a floor mat would be better?
Any pictures of carpet with the whole cut in it? Trying to see how clean we can make it using carpet.
Opinions? Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I don't have disc brakes but if I did I still like the M/C where I put it. Out of the way! ...its a 52 panel but here is what I did. Not too fancy but it serves the purpose.. I used a rubber floor mat and just turn it back if I want to check the M/C. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/MasterCylhole001.jpg | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | On my '56 restorod I used a remote dual reservoir mounted on the fire wall and this billet MC cover. Works great...without this you can use a mirror and squeeze bottle with a long straw to fill the MC from underneath if you want. http://www.kugelkomponents.com/zencart/index.php?main_page=index&cPath=49Mike B  | | | | | Joined: Nov 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 60 | Thanks for the ideas. I was looking at this finished edge molded carpet and thought I might be able to put some velcrow on the edge and pull it up to get to the master cylinder. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I used a remote reservoir kit as well in my 59 Suburban, not sure what I will end up with on the 58 2-ton, probably glue the carpet to some thick pad and as mentioned above, just pull it back when I need to check the master Cyl. Gluing the carpet to some thick jute pad (heavier fiber/hair type, not rubber) will make it lay a lot more like a rubber floor mat and not bunch up or wrinkle. | | |
