7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy), 136 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#1165684 05/17/2016 2:10 AM
Hello,
In the works of getting a 1947-1954 suburban, I already have a truck, with some extra parts. I was wondering where I can get side sliding glass for a suburban. The one I have in the works has all the trim and I'm not sure if the rest of the hardware for the driver side back glass is there yet. But either way I wanted to start researching where I can get replacement glass and seals along with any other parts. If anyone can point me in the right direction that would be great!
Guillermo Ortiz Jr.
1950 Chevy 5 window with a 54 GMC cab swap
Try calling Jim Carter Truck Parts.
They might have Suburban rear side glass, and/or they might have patterns for the side glass.
Ok thank you I will try calling them!
Guillermo Ortiz Jr.
Jim Carter has side glass patterns. If you have the old glass, they make great patterns for a local glass man.
Classic has a side window seal kit that covers everything for four windows. http://www.classicparts.com/1947-54...rip-Kit/productinfo/01-505/#.Vzsvo_krKM8
My tutorial on the install process: http://www.stovebolt.com/techtips/windows/suburban/side%20window/index.html
Thank you I will look into that! Do you know if they have the seals for clamshell glass? And the where I can get seals for the clamshell doors!
Guillermo Ortiz Jr.
I have found that some suppliers should have an AF suffix at the end of the part number. AF stands for Almost Fits. So I am now careful and research before I buy. Sis the Classic Parts items work well?
Thank you.....
Lisa
1952 Chevy Carryall in completely original condition
Pulled out of a barn in Colorado high desert
Thank you, for the info it's a big help
Guillermo Ortiz Jr.
