1 members (Steelonsteel), 75 guests, and 1 robot.
Topics128,050
Posts1,055,760
#116565 06/20/2005 3:07 AM
I
I Offline
In my searches I have not found info on where to get non-stainless steel bolt kits for my 49 1/2 ton. Can anyone help? THX
#116566 06/20/2005 9:08 PM
Hi 49,
Which bolts are you looking for? If you can tell us exactly which bolts you need, we may be able to help you out.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#116567 06/20/2005 11:22 PM
The Filling Station (541) 258-6968 has Zinc and cad hardware kits.
#116568 06/21/2005 2:51 AM
Kimberly:
What do the screws look like that hold the window frames to the regulators in a 1950? Mine are missing and I think I'll end up grinding down the heads of some 1/4" flat heads but there isn't much room in there.
#116569 06/21/2005 4:26 AM
Anonymous
Unregistered
Anonymous
Unregistered
Scotts Super Trucks has Cad. Bought the bedwood and bed to frame bolt kit, very complete and good prices. Just Curious, why don't you want SS?
#116570 06/24/2005 2:32 AM
I
I Offline
Sorry it took so long to get back to you all. I need almost every bolt for the body as most where damaged during desassemble.
As for stainless I have heard about corosion issue with the steel parts and I would think the steel would be much less costly. Is $300 normal for a complete kit? THX for the responses. Hope to get the truck back together in the next couple on months. Of course it was suppose to be done by now
#116571 06/24/2005 3:39 AM
there can be galvanic reaction between the ss bolts and the plain steel parts - helps if ya use some Never-seeze on the threads - the main problem is the ss bolt and nut will 'weld' itself together, but of course if ya do a good job in the first place you should never have to take it apart again! grin
300 sounds steep for the cad plate, but maybe ball park for ss
#116572 06/25/2005 1:27 AM
Sorry it took me so long too! I "volunteered" for another project on the site, and its been eating up waaaay more time than I'd planned, but all for a good cause.
That said, here is some info that you may find helpful:
CHEVY DUTY
Door Screws (original type) for door control, striker, and window regulator are sold by
Chevy Duty. Part number: 18-921 for clutch head, Part number 18-922 for Phillips.
Phillips Flat Head Screw with star washer: Part no. 18-911
www.chevyduty.com
TRUCK SHOP
Door handle relay screws: Part no. 47-02205
Window Regulator screws: Part no. 47-02212
www.truckandcarshop.com
JIM CARTER
Door Glass lower frame screw kit: Part no. WI-226
www.oldchevytrucks.com
Each of these vendors should be able to get you as-original bolts/screws for all parts of your truck. You can download Chevy Duty and Jim Carter's catalogs online; you don't even have to wait for the mail!
There are others, but these were the ones I had handy. Good luck!
~ Kimberly
#116573 06/29/2005 5:16 PM
ia49 get an ARP catalog, they have every kind of bolt known to mankind, maybe a bit expensive but top quality.
