3 members (Nick in Manitou, CuzzFuzz, Tronman), 115 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
#1164320 05/08/2016 12:55 AM
Sometime in December I had mentioned how my t5 performed with what I believed to be a 5:14 rear end.
Well I recently pulled the 3rd member to find out what all the whining was about and upon counting the revolutions of the pinion verses the crown gears I came up with a 5:38 ratio.
I could see no obvious problems so I took it to a rear end specialist who could find no issues other then some minor preload adjustments ,and he too said it was a 5:38
Doing a little research on the interweb I found little mention of this ratio other then to say it was od ball !
I will reinstall this rear end and see if the adjustments eliminate the whine, the rear end guy suggested it might be the nature of the beast given the ratio and the rev's its turning when I break the 50 MPH mark.
The 4:10 gears I had planned to install apparently had been stored out side and the bearings and races were pouched and to expensive to replace.I am now searching for a 4:56 or a true 5:14 , so if there is anybody in the TORONTO CANADA are with one to sell please post on this sight.
good planning is no substitute for dumb luck
If you haven't already try posting a parts wanted ad in the Swap Meet section.
•1952 Chevrolet 3800 pickup
---All pictures---
panel fan - If the ring gear and pinion gear on that 4:10 are in good condition, I would be interested in them. PM me if you would like to discuss.
Ron - - Dusty53
1954 Chevy 3604
Dusty 53. Thanks for the offer but I think I'll hang onto it as I've not quite decided where I'm going with this build and Id hate to part with some thing I might need in the future
I understand completely.Thanks.
Ron - - Dusty53
1954 Chevy 3604
