4 members (52Carl, FishinToms53, dinosoar, 1 invisible), 78 guests, and 3 robots.
Topics128,127
Posts1,056,677
Members48,452
I'm sure my answer is on the forum somewhere but I can't figure out the search. So the question is what is a good manifold for the S-10 and SBC conversion without cutting a bunch of stuff up?
thanks
dont under stand your question, are you asking what is a good manifold for a sbc conversion into what kind of truck..
conversion from what to what
Redryder pix
My Hotrod
Depends where you're placing your engine and what cab you are using, etc. Factory rear-exit manifolds (think 70's-80's) usually work.
Ram's horns likely won't work.
My 46 GMC on Photobucket
Redryder pix
My Hotrod
Riding in the Passing Lane
I used a special set of headers made for that swap. They are not cheap though.
1972 Chevy c10 Cheyenne Super
The headers are made for the V8 S-10 swap. They may or may not work if you're swapping the body as well, as your engine likely is in a different spot than if it were still an S10. At least mine is.
Thanks for the input.
SS
