0 members (),
95
7
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I removed the horn button from my truck. I cleaned and painted the bow tie. Now for some reason I can't get the horn to work after putting the button back on. I've removed it once before but never had a problem with getting it to work again.
Is there a certain connection that has to be made between the inside of the button and the teeth on the metal ring on the horn assembly? It's seems like it has a snug connection. I don't know why the horn itself would die. No wires were disconnected. The battery is charged so no lack of current.
Thanks for your help. Mark
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Just fixed it. No harm no foul. | | |
