1 members (TPR57C), 367 guests, and 4 robots.
Topics128,159
Posts1,057,033
Members48,460
I have a Yankee 960 4 wire turn signal set up and I want to hook it back up. What type of flasher do I need and how do I test the system before hooking it up? Thanks! It's still a 6 volt neg ground .
I would guess a 4 wire would be one wire for flasher input, one for pilot light, one for both left lights and one for both right lights. If so it needs a 3 prong flasher it you want the pilot light to work.
This tech tip tells how to determine what wire is what.
That is a good looking Art Deco switch. 4 wire switch works with separate turn signal lights. More wires on the integrated brake/turn signal system. The switch is pretty enough to possibly add the extra lights in the back.
Steve H
Its in almost pristine condition. My goal is to put new turn signals on the fenders in the front. I want to test the whole system before installing. I think I have the wrong flasher. I need to make sure it works before install.
JS
JS,
Very good idea - bench testing the wiring/components.
Good luck - please report back with results of both the test and the installation.
