0 members (),
125
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 28 | I have a Yankee 960 4 wire turn signal set up and I want to hook it back up. What type of flasher do I need and how do I test the system before hooking it up? Thanks! It's still a 6 volt neg ground . | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I would guess a 4 wire would be one wire for flasher input, one for pilot light, one for both left lights and one for both right lights. If so it needs a 3 prong flasher it you want the pilot light to work. This tech tip tells how to determine what wire is what. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | That is a good looking Art Deco switch. 4 wire switch works with separate turn signal lights. More wires on the integrated brake/turn signal system. The switch is pretty enough to possibly add the extra lights in the back.
Steve H
| | | | | Joined: Aug 2006 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 28 | Its in almost pristine condition. My goal is to put new turn signals on the fenders in the front. I want to test the whole system before installing. I think I have the wrong flasher. I need to make sure it works before install.
JS | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | JS,
Very good idea - bench testing the wiring/components.
Good luck - please report back with results of both the test and the installation. | | |
