6 members (gswbbc, Hotrod Lincoln, Gdads51, Ponchogl, Brian Moore, 1 invisible), 141 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1163681 05/03/2016 9:14 PM
I'm looking for some help on the next steps for troubleshooting.
'37 Chevy 1/2T
Ammeter was always showing above 0 bouncing around and seemed to dip (left) with headlights and / or brake lights illuminated.
Now the meter reads straight up zero with the vehicle running. It will dip (left) with above lights as well. Truck off the gauges falls completely left.
After charging the battery fully, I started the truck and measured 6.5 - 6.7 VDC at the output of the regulator.
Where should I go next?
Justin
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
H Online: Content
Disconnect the wires at the back of the ammeter, being sure to label which wires go to which post. (Take a picture if possible) The meter needle should go to center. If not, you have troubles inside the meter. Repair or replace it. If it does center, reconnect the wire from the starter connection battery cable. Again, the meter should stay centered. If it's wired right, that should be the only wire attached to that post of the ammeter. Reconnect the other wires one at a time. If one is shorted, or has a high-resistance voltage leak, the meter will deflect when the leaky wire is connected.
I'm going to guess you have an internal problem in the ammeter.
Your voltage at the regulator indicates it is not charging at that point.
1951 1 Ton Completed
