4 members (lumbersawyer, Hush, 2 invisible), 64 guests, and 3 robots.
Topics128,026
Posts1,055,407
Members48,422
#1163707 05/04/2016 1:11 AM
On my speedo, at 65mph, GPS reads 57mph do I live with it or change something or get adapter? 53 3100 235 4 speed 3.73 rear 235x75x15 tires. root
root #1163713 05/04/2016 1:42 AM
Since your rearend ratio has been changed, the error will be different at different speeds. I would take a number of different readings at different speeds and then decide if it something that can be lived with. You can buy an adapter to correct for the error if you know what it is.
1951 1 Ton Completed
root #1163844 05/04/2016 11:27 PM
Thanks trucker, yes at 30 its 30 at 45 its 41 at 55 its 48 and at 65 its 57. So I think I will live with it. root
root #1163873 05/05/2016 2:10 AM
It looks like you are about 14% low so if you have an adaptor made to increase the cable speed by 1.14 all of your ranges will be very close.
This ebay seller custom makes GM adaptors...
http://www.ebay.com/itm/Speedometer-Ratio-Adapter-GM-Chevy-/272216365964?hash=item3f615c1b8c:g:yUEAAOSw~oFXFSdk&vxp=mtr
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
