4 members (klhansen, J Lucas, Peggy M, Otto Skorzeny), 96 guests, and 3 robots.
Topics128,088
Posts1,056,390
Members48,442
#1159101 04/08/2016 2:46 AM
Does anyone know if MT sells installation kits for their ring&pinion sets for the 47-55AD's. Have a ring & pinion along with the installation kit on order with Patrick's. Been waiting 6 mos and still don't know when I am getting them. Very frustrating. But I do not want to cancel until I have another source.
thrs50 #1159107 04/08/2016 3:01 AM
thrs50 #1159109 04/08/2016 3:13 AM
MT has the R&P in stock.
I think he does not sell any installation kit.
Classic Parts sells an installation kit. You'll have to call them to see if your kit is in stock.
Make sure it matches your year. There were differences in a few parts between 1947-1954.
I do not know about 1955st series 3.55 R&P conversion.
thrs50 #1159302 04/09/2016 1:50 AM
Haunting the SBP since 2001
Looks to me like MT has these gear sets "Stacked To The Ceiling" & ready to ship.
http://www.jalopyjournal.com/forum/...-ring-pinion-gears.923013/#post-11403559
thrs50 #1159788 04/11/2016 5:54 PM
If you observe, MT advertises them for 47 to 53. With a little modification, they can be made to fit a 54. However, the 55 1st and later is an open drive shaft and requires a completely different gear set. I agree with Tim. If there is a 3.55 gear set made for an open drive shaft, I have never heard about it.
thrs50 #1159792 04/11/2016 6:14 PM
"With a little modification, they can be made to fit a 54."
What is needed in 1954 is an earlier 4.11 1/2 ton truck carrier for the ring gear. Just swap it in.
"However, the 55 1st and later is an open drive shaft and requires a completely different gear set. I agree with Tim. If there is a 3.55 gear set made for an open drive shaft, I have never heard about it."
There is a 3.38 R&P set available for the later, open-driveshaft 3.90 rear ends.
Here are some sources (MT does not sell a set - unfortunately):
1. https://totalmetalinnovations.com/i...p;zenid=5587fdb8114a7f23a30f08424d7de76b
2. http://www.justdifferentials.com/GM55T-338-NG-p/gm55t-338-ng.htm
3. http://www.classicparts.com/1955-62-Rear-End-Gears-338-Ratio/productinfo/93-513/#.VwvaoRMrKdE
Installation kit #1 (get one of these two kits)
Installation kit #2 (get one of these two kits)
Patrick's 3.38 R&P gears - could be slow to deliver
[quote=tclederman]
(MT does not sell a set - unfortunately) [quote]
It sure looks like MT carries those 55-62 gears to me.
http://www.jalopyjournal.com/forum/...ring-pinion-gears.1015591/#post-11476035
thrs50 #1159855 04/12/2016 12:03 AM
Thank you very much, simplex
Joe would be irked by my incorrect information.
Looks like that post on the HAMB was made 28 minutes ago by MT? (a few minutes before your submitted your post here)
Would someone post contact info for MT?
You have to be a HAMB member to contact him at the HAMB link, I think?
check your P.M.
thrs50 #1163255 05/01/2016 12:52 PM
Does anyone know the difference between the two installation kits. I have a 50AD but the rear brakes are not the Huck type. I am assuming that I have a 51 or newer rear end. I have suspicions that the truck maybe a 52. So I am trying to figure out what kit to buy. The front end has the Huck style brakes.
thrs50 #1163263 05/01/2016 2:30 PM
One difference might be the Okie (drive shaft) Bushing?
1940/41-1950 bushing
1951-1954 bushing
The bushings is the only different in the photos (if photos are correct):
41-50 parts set
51-55 parts set
thrs50 #1163281 05/01/2016 4:46 PM
Your axle should have a code stamp on the housing. It will start with H for '50, J for '51, K for '52, etc. I think for the half tons.
Check
http://chevy.oldcarmanualproject.com for details.
My 51 had a 50 axle, with Hucks, that's how I figured it out.
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
