8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 7 New Guy | | New Guy Joined: Mar 2012 Posts: 7 | hello all,
it seems i have purchased a real rust bucket. as i have been tearing it down i have found rust holes in the frame rail vertical section as well as the cross member directly below back of cab/start of bed and some heavy pitting in areas on the horizontal.
the end goal is a semi original daily driver, 228 or 302(if budget allows) t5, slightly lowered otherwise stock
so what is the difference in frame years and easiest swap regarding cab/fender/bed mounts. i was thinking maybe 50? up to take advantage of tubular shocks???
aside from front motor mount are the chevys compatible
thanks, ryan | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You are correct on the motor mount/crossmember difference. The '50 and up will get you the tubular shocks which allow easier maintenance and ride. What are you doing with your fuel tank? Will it remain on the frame? If so save all the parts as they are hard to source and expensive. | | | | | Joined: Mar 2012 Posts: 7 New Guy | | New Guy Joined: Mar 2012 Posts: 7 | yea brad will probably keep the tank in frame. found some info on the other site. sounds like it will be a pretty "easy" swap if i happen to go the chevy route. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The front crossmember/mount can be swapped out. The cab mounts will also be different. | | |
