3 members (mason86, Hotrod Lincoln, UtahYork), 61 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#1162479 04/27/2016 6:30 AM
Not sure if this has been covered....did a search could not find anything....has anyone did a 12 volt wiper conversion and used the old switch? If you did....how did you do it?
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
Jayson52 #1162503 04/27/2016 12:59 PM
I replaced the original wiper motor with an electric motor. My system had already been upgraded to 12v but as far as the switch goes it does not matter 6v or 12v. The switch will work with both. It is only a physical connection. There are no working electronics that could be damaged by increasing the voltage. If you are asking about the knob in order to keep the original look there is a set screw on the side of the switch knob that will allow you to install in on the new shaft of a new switch/motor.
Dave from Northern Kentucky
My 54 3100
Jayson52 #1162704 04/28/2016 9:56 AM
The original wiper knob has no set screw
Not sure if the replacement does either
...pic...
I drilled and tapped a replacement for a set screw
Jayson52 #1162713 04/28/2016 12:55 PM
I double checked. You are correct about the original know. It was just pressed on. The new one that came with the replacement motor has a set screw. The know from the replacement motor is a replica of the original. I put it on but saved the old know just in case.
My 54 3100
Jayson52 #1162915 04/29/2016 3:54 AM
I do want to keep the original look, there is not a lot original left on this truck but I like the old look with updated parts so to speak.
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
Jayson52 #1163067 04/30/2016 1:49 AM
The problem with the modern switch is the bezel nut
...example...
Jayson52 #1163185 05/01/2016 1:47 AM
Leo Offline
Moderator
Moderator
If you want the original look, just leave the old knob there. Install the new knob out of the way.
Jayson52 #1163327 05/02/2016 12:13 AM
Originally Posted by red450IH
I have updated my photos with descriptions. I will do a write-up when I get more time.
I feel like this will work for 1954/1955 first also. I bought all three knobs when I started as I did not know the differences and thought one may work easier than another for this project. Turns out all three knobs can be slightly modified to fit the Ford delay and non-delay switch. Hope this helps someone.
Link:
https://plus.google.com/photos/1055...60484243705462577?authkey=CK6apuON_pONRA
Jayson52 #1163576 05/03/2016 3:16 AM
I followed Reds instructions for delay wipers in this post:https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=911824
I think it looks good and works better. Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
MtneerMike #1165801 05/17/2016 9:54 PM
Hey DAD50 , I wanted to PM you but find that your "over your limit " . Darn it !
Ron - - Dusty53
1954 Chevy 3604
Jayson52 #1165829 05/18/2016 1:53 AM
Gas Pumper
Gas Pumper
I noticed the cost of two speed and/or intermittent wipers is really high. I wonder if we could add a circuit that gives you both for a lot less cost than what is being advertised.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Jayson52 #1165837 05/18/2016 2:14 AM
Well get busy MacGyver! smile
We are waiting...
Last edited by 52Carl; 05/19/2016 3:56 AM. Reason: I can spell, I can't see. That's the problem.
Jayson52 #1165840 05/18/2016 2:28 AM
Gas Pumper
Gas Pumper
http://www.newportwipers.com/optacc.php
Have you guys seen this? Two things that are pretty cool. An $80 solution to the issue I brought up above, and also for you stock wiper knob fans, the bottom of the page, an extension for the switch that would enable you to drop the main switch below the dash and the stem could be fastened to the stock switch?
Deve
The Think Tank
Jayson52 #1165882 05/18/2016 1:05 PM
Id like to see a better picture of the adapter
Does the nut fit on top or bottom
Jayson52 #1165887 05/18/2016 2:15 PM
Gas Pumper
Gas Pumper
Dunno. It says its available for different companies, so not sure how accurate the picture is. I guess for $20 you can find out. It looks plausible.
Deve
The Think Tank
Moderated by  ndkid275, Phak1
