Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Shade Baby, 55shaker, Pre '68 Dave, 1 invisible), 106 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
Just installed my new accelerator pedal on my 1949 Chevrolet 3100 1/2 ton truck with 216 cu.in. engine.
The pedal is approximately 1" from the floor when released and seems to go to full throttle. How far away from the floor should the pedal be when released? Doesn't seem to have much throttle travel?
Had to bend the rod slightly so that it would not bind on the hole through the floor board. Any ideas or suggestions?
Tim
1970 VW Beetle
The pedal on my "49 is approx. 2-1/2" from the floor mat to the surface of the pedal when measured at the top of the pedal.
Ed
Fixy, are you sure that you can achieve full throttle with only one inch of pedal travel?
Are you using the original bell crank and have it installed correctly? (I don't know if it is possible to instal it wrong.) Something isn't right.
Carl
