4 members (fonz8261, Otto Skorzeny, King Kielbasa, 1 invisible), 90 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#116269 03/07/2003 1:14 AM
I just got my front splash apron and i'm trying to see how it fits up to the grill. The PO screwed me up by welding in home made bumper brackets so I,m not shure how to fit it in. Does it go under the grill or in front of or corner to corner?
if it dosen't need fixed, break it
#116270 03/08/2003 4:59 AM
The one I have is a fiberglass one but I think it mounts the same as the metal ones, it has an indentation in the middle that has the same contour of the bottom bar of the grill. this indentation slides under the grill bottom and the mounting tabs go behind the bumper brackets.
#116271 03/08/2003 8:16 AM
That's right. Also, the indentation is painted white if you have a chrome grill or thistle gray if you have a painted grill (for all exterior colors except Commercial Red and Pure White).
Tim
#116272 03/08/2003 2:25 PM
Also, don't forget to stack bumper washers as needed to take up any irregularity in the contour of the apron and the contour of the bumper. If you try to just suck it down hard the apron will warp and you will bend it. You have to carefully fit the apron by stacking washers in the voids with the bumper brackets to prevent dimpling or warping it when you snug it up.
#116273 03/10/2003 4:04 AM
Tim,
I have a '54 and just took apart the grill, I see the thistle white thru the PO's lousy paint job on the middle and bottom pieces, but not on the splash panel, was it always painted white there ? Also do you have the dupont # for the Thistle white color by any chance ?
#116274 03/10/2003 4:30 AM
Thistle Gray (the outer part of grill bars and pan were body color; and, the inner part of the grill bars and the recess in the grill pan were thistle gray).
Dupont Dulux 93-70397
Ditzler DAL-30873-DQE
PPG 30873(originally), but now 32669
#116275 03/10/2003 4:40 AM
Tim,
Thanks for the info !
