| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I just got my front splash apron and i'm trying to see how it fits up to the grill. The PO screwed me up by welding in home made bumper brackets so I,m not shure how to fit it in. Does it go under the grill or in front of or corner to corner?
if it dosen't need fixed, break it
| | | | | Joined: Jan 2002 Posts: 32 Member | | Member Joined: Jan 2002 Posts: 32 | The one I have is a fiberglass one but I think it mounts the same as the metal ones, it has an indentation in the middle that has the same contour of the bottom bar of the grill. this indentation slides under the grill bottom and the mounting tabs go behind the bumper brackets. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That's right. Also, the indentation is painted white if you have a chrome grill or thistle gray if you have a painted grill (for all exterior colors except Commercial Red and Pure White).
Tim | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Also, don't forget to stack bumper washers as needed to take up any irregularity in the contour of the apron and the contour of the bumper. If you try to just suck it down hard the apron will warp and you will bend it. You have to carefully fit the apron by stacking washers in the voids with the bumper brackets to prevent dimpling or warping it when you snug it up. | | | | | Joined: Jun 2002 Posts: 81 Member | | Member Joined: Jun 2002 Posts: 81 | Tim, I have a '54 and just took apart the grill, I see the thistle white thru the PO's lousy paint job on the middle and bottom pieces, but not on the splash panel, was it always painted white there ? Also do you have the dupont # for the Thistle white color by any chance ?
Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thistle Gray (the outer part of grill bars and pan were body color; and, the inner part of the grill bars and the recess in the grill pan were thistle gray).
Dupont Dulux 93-70397 Ditzler DAL-30873-DQE PPG 30873(originally), but now 32669 | | | | | Joined: Jun 2002 Posts: 81 Member | | Member Joined: Jun 2002 Posts: 81 | Tim, Thanks for the info ! | | |
