7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 26 | I have a 47 1.5 ton loadmaster. Does anyone know of a source/part number for a front wheel bearing thrust washer. To clearify, the washer behind the adjusting nut. Any help would be appreciated. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Anyone with basic welding skills can fabricate one in a matter of minutes, if an original equipment part can't be located. If you have a part to use as a pattern I'll be glad to make one for you. Jerry
| | | | | Joined: Sep 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 26 | Thanks Jerry great idea, sounds like a fun project. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Just take a flat washer the right size to fit the spindle, cut a slot in it, and weld in a tab across the full width of the washer. Then file-fit it to the lock slot. Jerry
