0 members (), 91 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#1162634 04/28/2016 12:35 AM
I have a 47 1.5 ton loadmaster. Does anyone know of a source/part number for a front wheel bearing thrust washer. To clearify, the washer behind the adjusting nut. Any help would be appreciated.
Anyone with basic welding skills can fabricate one in a matter of minutes, if an original equipment part can't be located. If you have a part to use as a pattern I'll be glad to make one for you.
Thanks Jerry great idea, sounds like a fun project.
Just take a flat washer the right size to fit the spindle, cut a slot in it, and weld in a tab across the full width of the washer. Then file-fit it to the lock slot.
