1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I have a 49-3100 with a 235. I plan to install Fenton headers. Anyone have pictures of a exhaust system with Fenton headers. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 |
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | If you get stuck I can take some pics of mine and send them to you.
| | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Yes I would like pictures. I will PM you with my e-mail. | | | | | Joined: Feb 2011 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 38 | Here are 2 photos of mine. To save you some money from my error, I will have to get my installer to modify this system slightly to accommodate a spare tire carrier. https://flic.kr/p/H3iW3Rhttps://flic.kr/p/GZmGjwThe front exhaust takes a 90 degree to go under the shallow end of the oil pan, and another 90 to head rearward. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is Patrick's dual exhaust system. It will give you an idea of how/where he routed the pipes. The tail pipes "empty" out/under the rear side with pipes "over/under" each other. | | |
