| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | During a little cruise last night, I noticed that I was having a hard time getting into first gear. It was grinding bad, sometimes even second gear. What adjustment/maintenance is needed? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Have you checked the clutch pedal free-play (free pedal travel) adjustment?
What year truck/engine and what transmission? | | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | its a 1959 chevy apache 3100, with a 235, and a three speed on the column. Where would that adjustment be? Thanks | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | driver side, the linkage between the pedal and throwout arm is what you need to adjust. | | |
