0 members (),
123
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I felt like they s/b pointing to the front vs to the back or down, but the clearance between the body beltline is close- easy to scratch the paint. Pointing down allieviates that but it may look weird. COMMENTS? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe the stock orientation is horizontal but it's your ride. If you like them different who's to say you're wrong.
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | i was concerned that they may scrape the body bulge, but simply put one washer behind the handle end to shim it out. Looks and works well. Now all I need to do us install the windlace/track and hope the glass fits. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I like them pointing forward which is original. You can check the pictures in the gallery.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If yours are too close to the bodyline, it may be due in part to 76 years of wear. They should point forward, anything else would look silly in my opinion. I'm glad you figured it out. | | |
