6 members (46 Texaco, Opelika Tom, ndkid275, Stan 58, RoadsScholar, Otto Skorzeny), 100 guests, and 0 robots.
Topics128,083
Posts1,055,967
Members48,430
#1161605 04/21/2016 6:36 PM
I have a problem with both of the running board splash aprons on my 1951 3600. The bracket at the rear of both has broken off. It is the bracket that was bonded to the apron on one end, and has a hole in the other end for bolting onto the truck. I have both of the brackets, but they look as though they were originally bonded to the apron with something. Does anyone know what that bonding method was or recommendations for bonding? Any advice on the exact location of these brackets when reattaching them?
Fox Offline
The little tab at the back of the apron attaches to the rear fender.
I think that the little tab was spot welded onto the apron.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
They were spot welded on.
Gas Pumper
Gas Pumper
Mike, I have a few examples at the shop. Feel free to stop by anytime. We can fix whatever is broke OR break it beyond repair. Whatever makes you happy! wink
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Should have mentioned the aprons have already been painted so a spot weld is not an option. How good do y'all feel about JBWeld in this case?
I would be more confident with panel adhesive for this application. There is a lot of flex going on in this area, which is why those spotwelds often fail. You have nothing to lose by trying the J-B weld, however.
Carl
Don't bother with the JB weld there.
try this.
Give me ambiguity
or give me something else
If I recall when I took my rear fenders off, the tab spot weld wouldn't have been visible, but I may be wrong. If it were me, I would fab up a longer tab and use the panel adhesive that Caso recommended and give it more to attach to.
Point well made, Kevin. That flange would not show. It might even work to rivet the pieces on. Thanks for the V8 slap on the forehead!
That panel adhesive is very pricey, and you need an even more pricey applicator gun. You will have to buy a full tube and only use less than an ounce. You could probably buy 2 brand new splash panels and have them painted to match your truck for what you will spend on the panel adhesive kit.
Then maybe you use this size for smaller jobs.
Give me ambiguity
Good find, Caso! Local paint stores around here don't offer that size.
