0 members (),
230
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 38 | I have a problem with both of the running board splash aprons on my 1951 3600. The bracket at the rear of both has broken off. It is the bracket that was bonded to the apron on one end, and has a hole in the other end for bolting onto the truck. I have both of the brackets, but they look as though they were originally bonded to the apron with something. Does anyone know what that bonding method was or recommendations for bonding? Any advice on the exact location of these brackets when reattaching them? | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | The little tab at the back of the apron attaches to the rear fender. I think that the little tab was spot welded onto the apron. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | They were spot welded on.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Mike, I have a few examples at the shop. Feel free to stop by anytime. We can fix whatever is broke OR break it beyond repair. Whatever makes you happy!  | | | | | Joined: Feb 2011 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 38 | Should have mentioned the aprons have already been painted so a spot weld is not an option. How good do y'all feel about JBWeld in this case? | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I would be more confident with panel adhesive for this application. There is a lot of flex going on in this area, which is why those spotwelds often fail. You have nothing to lose by trying the J-B weld, however. Carl
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Don't bother with the JB weld there. try this.
| | | | | Joined: May 2015 Posts: 11,060 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,060 | Should have mentioned the aprons have already been painted so a spot weld is not an option. How good do y'all feel about JBWeld in this case? If I recall when I took my rear fenders off, the tab spot weld wouldn't have been visible, but I may be wrong. If it were me, I would fab up a longer tab and use the panel adhesive that Caso recommended and give it more to attach to.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2011 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 38 | Point well made, Kevin. That flange would not show. It might even work to rivet the pieces on. Thanks for the V8 slap on the forehead! | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | That panel adhesive is very pricey, and you need an even more pricey applicator gun. You will have to buy a full tube and only use less than an ounce. You could probably buy 2 brand new splash panels and have them painted to match your truck for what you will spend on the panel adhesive kit.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Then maybe you use this size for smaller jobs.
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Good find, Caso! Local paint stores around here don't offer that size.
