0 members (), 139 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
Picked up this very, very nice orginial '64 half ton with the 230 engine. Thinking about adding power steering IF possible and making it my daily driver, it's that nice. I'm older than I care to admit and got 'flashbacks' from the manual steering.
If it's possible with this engine would you care to 'flesh' it out for me. I do restores and hot rods so I'm not a newbie.
H Online: Content
You might consider one of the new-design electrically-assisted steering systems. It might be a simpler modification than replacing the steering gear, mounting a pump, running hydraulic lines, etc. There should be plenty of them in salvage yards and a little internet research will probably turn up what's necessary to do the conversion.
Thanks Jerry. That's a path that I had not thought of taking. I'll do a little research and see what is available.
I had a good look at the front of the 230 and said to myself. "Self, this is not going to be a cakewalk."
The inlines had power steering available to them, and the brackets show up on e-bay every now and then. The pump mounts under the alternator so you need both sets of brackets to make it work and a dual belt pulley for the balancer (I think). The rest will bolt on.
Riding in the Passing Lane
You can mount a later model power steering gear with a bracket set available from specialty supliers like Speedway or CCP.
I think Joe meant the pump goes over the alt. You will need the bracket sets like he described & a double groove water pump pulley.
1972 Chevy c10 Cheyenne Super
Sorry about that, pump does go above the alternator.
I had the set up on my 64/230. Bought the brackets from Tony at 5-6-7. They should be in the barn if I can find them. Send me a note and we'll talk.
Tramp
dj durant
More pix on Flickr
