6 members (J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE, ShopRag), 83 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#1161277 04/19/2016 4:27 PM
Project is a 47 3100. Using a 54 235. I have two distributors, one from the original 216 that is model #1110090 it is a short cap. The other is a swap meet find model #1112396 and it is a tall cap. From doing a little research the #1112396 is for a 54 235 with powerglide. I am not using a powerglide. I plain to use a pertronix # 11168LS with the 3.0 ohm flame thrower coil. With the powerglide distributor I’m guessing that the advance curve will be ok. Am I guessing wrong? Or would the original out of the 216 be a better choice? If the advance curve on the #1112396 is going to be an issue could I just swap the springs? Both distributors look good. Thanks for any help.
The 090 distributor is a reverse polarity distributor Chev tried from 1941-48. I would stay away from that one as it uses special points, and needs slight modification to ground the points plate.
I would recommend the 396.
Here is a list of distributor numbers by year on my blog.
My Blog
One needs to be careful about which cam/distributor gear combo you use.
If your engine has a cast cam it is not recommended to use a steel distributor gear. My blog post on distributor gears.
My Blog
