5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#116138 05/10/2004 8:05 PM
Junior Member
Junior Member
When a patch panel is applied and you are butt welding, I know you are supposed to weld small areas at a time spacing them every inch or so. Once you have it all welded,still having the gaps,
do you completely weld up every gap till no holes remain or is it ok to leave some tiny gaps and fill in later when you do the body filler work.
#116139 05/10/2004 9:40 PM
Z
Z Offline
Fill them in, only leaving the gap's to keep the heat down when welding in the panel initially to stop distortion, should be a solid weld when finished, Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
