5 members (Johnny Rib, Otto Skorzeny, dwreills, Wickedbass, TooMany2count), 114 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
I bought an engine that was removed from a 56 chevy 4000 truck for $100. It was going to the scrapper if I didn't take it. Got it home and snapped a picture of the casting number on the RH side of the crankcase. (3836340)[IMG]http://i305.photobucket.com/albums/nn214/jfnar/57%20chevy%203800/IMG_0340_zpsbkhj1abe.jpg[/IMG]
According to the casting number buster listed in the post above this is a 261 engine but there is only one captain's bar above the starter. Can anyone verify if this really is a 261? It hasn't run in a few years but it turns over and I will definitely bring it back to life if it's a 261. Thanks for any help you can provide.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
That is a 261 block casting code.
1. What is the Engine Serial Number that is pressed into the block to rear of the distributor?
2. What is the block date casting code: distributor side of the block, lower left?
It might look a little like this.
The CON 4 indicates the conveyor in the engine assembly plant.
The code on the right is the date casting code.
I'll have to take a look at the other numbers tonight. I'll post what I find tomorrow. Thanks.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
CON 3 E235
0598887F255N
3836848
Also, there is a little green paint under the crud on the crankcase and side cover.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
CON 3 E235
E235 = E 23 5
E = 5 = May
23 = 23rd
5 = 1955
0598887F255N
F = Flint, MI engine plant
255 = 1955-2nd series truck engine
N = 6000 series truck with RPO-255 261 truck engine
3836848 = 1956 through 1962 head
Your $100 was well spent.
Tim,
That's great news. Thanks for the confirmation. It was even built on my birthday, even though it was just a few years ahead of me. Definitely worth saving from the scrapper. I'll store it away for now until I have time to go through it. Thanks again for the help.
Jeff
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
