| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I bought an engine that was removed from a 56 chevy 4000 truck for $100. It was going to the scrapper if I didn't take it. Got it home and snapped a picture of the casting number on the RH side of the crankcase. (3836340) [IMG]http://i305.photobucket.com/albums/nn214/jfnar/57%20chevy%203800/IMG_0340_zpsbkhj1abe.jpg[/IMG]According to the casting number buster listed in the post above this is a 261 engine but there is only one captain's bar above the starter. Can anyone verify if this really is a 261? It hasn't run in a few years but it turns over and I will definitely bring it back to life if it's a 261. Thanks for any help you can provide.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is a 261 block casting code. 1. What is the Engine Serial Number that is pressed into the block to rear of the distributor? 2. What is the block date casting code: distributor side of the block, lower left? It might look a little like this. The CON 4 indicates the conveyor in the engine assembly plant. The code on the right is the date casting code. | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I'll have to take a look at the other numbers tonight. I'll post what I find tomorrow. Thanks.
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | CON 3 E235
0598887F255N
3836848
Also, there is a little green paint under the crud on the crankcase and side cover.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | CON 3 E235
E235 = E 23 5
E = 5 = May 23 = 23rd 5 = 1955
0598887F255N F = Flint, MI engine plant 255 = 1955-2nd series truck engine N = 6000 series truck with RPO-255 261 truck engine
3836848 = 1956 through 1962 head
Your $100 was well spent. | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Tim, That's great news. Thanks for the confirmation. It was even built on my birthday, even though it was just a few years ahead of me. Definitely worth saving from the scrapper. I'll store it away for now until I have time to go through it. Thanks again for the help.
Jeff
