0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | 1950 3100 AD Pickup - Trying to push the side window outer rubber sweep into the little slot seems almost impossible. Anyone have any tricks? It doesn't appear there's a way to get it in through the end - looks like you just have to jam it in there?
1951 Chevy Panel Truck
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | It's been a few years since I did mine, but there was a good tech tip I used. (Link at top of page) | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | In the middle of the track there is a tab. Bend it out and push the rubber in from there. Middle to both ends. Make sure you have cleaned all the of the old hard rubber out of the track, should slide in easily. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Lube with dish soap to help rubber slide. I used a Q tip to get the soap in the channel.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I like to use a water-based lubricant that evaporates and leaves no residue (and has no oil-based or silicone-based components - and no aromatics) Walmart and any national pharmacy chain has a store brand. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I like to use a water-based lubricant that evaporates and leaves no residue [url=http://www.walmart.com/ip/Equate-Lubricating-Jelly-Personal-Lubricant-8-oz/22211160][/url] "Personal lubricant" - how appropriate, lol! Thank you experts for the advice. I will give it another try today, slathering with lubricant and pushing it in from the tab slot.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Thanks gentlemen - I got one side done today! Now that I know how to do it, the other side should be easy, right? ;-)
| | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | This post was perfectly timed as I'm in the midst of replacing my windows in my '50. I got the sweeps installed. Now are there any hints on how to staple new felt strips to the metal window trim?? That one has me stumped. | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Hey David, I enjoyed your gallery story, I just got my 3100 back on the road last year and had the same concern about attaching the felt strips to the inside window trim. I realized that there was no way to replicate the staple technique the factory used so I improvised. That "fuzz" is somehow embedded into a strip of very dense and thick mastic. My answer was to clamp the felt strip to the inner trim piece (all off the truck) and I drilled 7 evenly spaced 1/8" holes thru the fuzz/mastic and into the inside trim piece. I then permanently pop riveted the two pieces together. The head of the pop rivet embeds into that mastic and gets nowhere near to touching the glass when rolled down or up. My one picture w the pointer shows that you can barely see the rivet head (that's the whole idea, right?) especially since the rivet is black. Felt Strip/Pop Rivet | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Dido Ssrjim #4 flat head sheet metal screws. The same ones I used to secure the window channel. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I glued mine with Permatex Ultra Black. So far very secure and I like the removability factor.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I've attached the inner felt strips a couple of different ways:
1) Glued them in with black silicone, or
2) Throw away the original-style felt strips. Use velcro, just the fuzzy female side. Stick it on, looks just like window felt. I used self adhesive, but it loosens in hot weather, so next time I'll attach it with weatherstrip adhesive.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Felt sweep......the smallest aluminum pop rivet works well, touch up with black paint and can barely be seen. Removeable and strong or the pros. | | |
