Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Oswald, baldeagle, Gdads51, Jay R, greenie-reddy, 1 invisible), 47 guests, and 5 robots.
Topics128,004
Posts1,055,247
Members48,418
#1160425 04/15/2016 12:28 AM
My 235 has a crack in the block between cylinders. After occasional runs for several years the leak is worse. It is now showing in the crankcase.
What is a sealer I can try that will not plug the radiator? I only drive her once every month or two.
Fred
52 3600
69 C-10
Fred T #1160440 04/15/2016 1:22 AM
Try "water glass" (Sodium Silicate). It's available in quart bottles on Ebay at pretty reasonable prices. It's a very effective sealer on low-pressure cooling systems. I managed to seal a seep leak from the head gasket on the 503 GMC engine that I drove from Tennessee to the reunion in KC last summer, and Ed Pruss drove it on to Denver without any problems.
Fred T #1160477 04/15/2016 3:33 AM
Crusing in the Passing Lane
And I added 50% antifreeze for protection and still OK.
Ed
Fred T #1160479 04/15/2016 3:52 AM
Local drug stores sells liquid glass.
Also a product called K-Seal works very well to seal cracks. And it mixes with antifreeze that's already in the system.
Added it to our Chrysler 3 years ago due to small leak in head gasket, still running.
Using my inner google-foo I was able to find that Bar's Head Gasket Repair contains sodium silicate without a bunch of extra additives. Cost is $11 locally, which isn't much more than e-bay.
http://barsleaks.com/product/head-gasket-repair/
Now to flush the system and disconnect the heater.
Thanks to Jerry & others.
Fred
52 3600
69 C-10
