1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I received my Best Gasket set and attempted to fit the ball to the transmission. I started with the 4 supplied shims and found the fit to be too tight. I could move it just a tiny bit with 2 hands. It seemed very tight to me. I made a shim out of a piece of card stock and i could move the ball with just a moderate amount of force. I polished the ball and the ring before fitting. Will 5 shims have an adverse effect on the sealing of the transmission and torque tube? | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I used valve lapping compound to lap the ball to the transmission......Now 4 shims and I can move the ball with moderate force.
Jackie | | |
