8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom), 167 guests, and 0 robots.
Topics128,089
Posts1,055,988
Members48,430
#1160239 04/13/2016 11:51 PM
I received my Best Gasket set and attempted to fit the ball to the transmission. I started with the 4 supplied shims and found the fit to be too tight. I could move it just a tiny bit with 2 hands. It seemed very tight to me. I made a shim out of a piece of card stock and i could move the ball with just a moderate amount of force. I polished the ball and the ring before fitting. Will 5 shims have an adverse effect on the sealing of the transmission and torque tube?
JackieC #1160243 04/14/2016 12:28 AM
If you followed the instructions in the manual, I can't see were the extra shim will be a problem. Note the adjustment is made without the ball seal installed.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0712.htm
Ed
I used valve lapping compound to lap the ball to the transmission......Now 4 shims and I can move the ball with moderate force.
Jackie
