Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (FAST55, JW51, Ponchogl, Hanks custodian), 37 guests, and 3 robots.
Topics128,009
Posts1,055,297
Members48,419
#1160135 04/13/2016 8:46 AM
Just curious what everyone has done for wipers on 41-46 trucks. I converted to an electric wiper and the problem i have is while the motor has stops to park it as you drive the wiper will eventually end up on the roof. You can pull it back down but it eventually ends back on roof. Wiper blade is tight on shaft. I was actually thinking of going back to a vacuum wiper which always worked fine. Just curious.
thanks
Mike
COOLIE #1160165 04/13/2016 3:17 PM
12V or 6V?
I use these: http://www.speedwaymotors.com/Stainless-Deluxe-12-Volt-Electric-Wiper,38962.html
I've never had an issue with them going too high. Is your wiper arm positioned properly?
My 46 GMC on Photobucket
46gmcpu #1160201 04/13/2016 7:35 PM
That is the one I have. If I position the arm any different it will go on every divider strip over center of windshield. I am going to check it again and then I might take motor cover off. Thanks
COOLIE #1160236 04/13/2016 10:59 PM
I'm thinking either your motor is defective or something isn't set up properly. Maybe the wiper arm length or position is off, or the 90° sweep is too much.
Mine work great and if anything they park too low if the windshield isn't wet enough. They physically can't go up onto the roof when they're off, the park mechanism doesn't allow the shaft to move.
46gmcpu #1160256 04/14/2016 1:31 AM
I am all set now. I reset arm and all is good. I am sure i did this before.
thanks
