1 members (Ponchogl),
142
Mod | | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Stovebolters
Still waiting for parts but it got me to thinking about what do you Stovebolters do for long term storage??...
Do you jack them up off there tires???
Do you start them every week or two???
Also do keep motor vehicle insurance on them while they are parked??
Any insight would be great....
MikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | How long, is long term? What kind of storage "environment"? Stovebolt.com Tech Tip: Seasonal Advice My trucks hibernate from Nov-Apr in an unheated garage (deep freeze in northern NY - near you). 1." Do you jack them up off there tires???" No 2. "Do you start them every week or two???" No 3." Also do keep motor vehicle insurance on them while they are parked??" Yes Before Hibernation: - change oil/filter if driven more than 2,000 miles - add gas stabilizer to fuel tank - fill gas tank - go for a 30+ mile highway ride - park the truck in the garage for hibernation I have 6v Optima batteries that get left in the trucks during hibernation (no battery tenders). | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | If it's going to be longer than "seasonal hibernation". Do the things Tim listed above and just before shutting the engine off for the last time spray Engine Fog down the carb to coat the internals surfaces. Then jack it up to take the weight off the tires. If parked indoors, put a few Downy Dryer Sheets along the bottom of the seat back springs and a few under the seat to keep the mice away. If parked outdoors I'd use Moth Balls as they are stronger. Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, Mike - I forgot about the mouse repellent. I used moth balls for several years. My friend, Dave, gave me one of these mouse traps a fews years ago. It is the best mouse trap I have ever used/seen. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If it's going to be longer than "seasonal hibernation". Do the things Tim listed above and just before shutting the engine off for the last time spray Engine Fog down the carb to coat the internals surfaces. Then jack it up to take the weight off the tires. If parked indoors, put a few Downy Dryer Sheets along the bottom of the seat back springs and a few under the seat to keep the mice away. If parked outdoors I'd use Moth Balls as they are stronger. Mike B  I've never understood jacking up the vehicle. Especially if it's not on concrete. With radials, you don't get flat spots like you could with Bias ply. I never had done it and never had an issue. I can't say how well that one works, but what I know works well and is much simpler is some birdseed or grain in the bottom of the pail, with the stick up the side (a flagging stick is more than enough). | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 46gmcpu,
Neither of our techniques is "humane", but the technique I linked-to is a quicker-death (less "suffering").
Nonetheless, mice/rats/squirrels must be avoided/eliminated. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Do keep motor vehicle insurance on them while they are parked?? MikeC This is something I just discovered. If you start your insurance coverage in the fall November. While it is stored for the winter months, you can just cover your vehicle with comprehensive coverage. (fire, theft or vandalism) Then in April or May when you take it out of storage, you can add full collision coverage. The insurance company will prorate the remaining months. May thru November. Then in November when it is time to renew the policy, just ask to have it insured for comprehensive coverage again. There is no sense insuring for full collision coverage when your not driving it. The key is, you have to start the coverage at the right time of the year to gain the full benefit. (Savings) Note: Once you add to the years policy you can't undo it. i.e. Get refunded.
Last edited by jorb; 04/15/2016 2:24 AM. Reason: terminology errors Swapped liability with comprehensive
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | 46gmcpu,
Nonetheless, mice/rats/squirrels must be avoided/eliminated. As far as being humane they're exactly the same? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | This is something I just discovered. If you start your insurance coverage in the fall November. While it is stored for the winter months, you can just cover your vehicle for liability. Then in April or May when you take it out of storage, you can add full collision coverage. The insurance company will prorate the remaining months. May thru November. Then in November when it is time to renew the policy, just ask to have it insured for liability again.
Note: Once you add to the years policy you can't undo it. i.e. Get refunded. Your insurance must be different than ours up here. On my regular insurance, I can cancel or change it at any time. When I have something parked, I remove everything except fire, theft, and vandalism. On my classics, it costs me less than $450 for full coverage including collision for all 3 for an entire year. No sense changing the coverage. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | After reading my (jorb) above reply I realized I was using the wrong terminology. Instead of liability coverage, what I meant to say was comprehensive coverage. Which means; "Other Than Collision" covers damage to your vehicle caused by an event other than an impact or collision such as fire, theft or vandalism. Example; if you hit a deer, it's a comprehensive loss. If you miss a deer and wreck, then it is a collision loss and would not be covered unless you carried collision. Frequently-asked-questions - Does Hagerty write coverage for comprehensive only? Click on 4th plus + sign. Yes. "Comprehensive only" (other-than-collision) coverage is available when a car is undergoing restoration, part of a display (such as in a museum) or placed in long-term storage. Hagerty also offers coverage called Limited Trailer Paddock that provides collision coverage while your vehicle is trailered. I wonder what the definition of long-term storage is? Another option. Vehicle Under Construction coverage. Insurance Primer A Crash Course in Collector Car Insurance (The above previous reply error has been corrected to reflect this reply) | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | For an airplane engine "long term storage" is defined as longer than 90 days.
Weeds | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Jorb, what minimum coverage you need to carry and whether or not you can cancel or change within a year is up to local law.
Here, you only need comprehensive if you're driving it on the road. You don't need collision unless you have a loan on the vehicle. And you can change or cancel your coverage at any time and get a refund. Best for anyone to check what's needed in their area. | | |
